I’m Stefan from Rikus-automove.
And I am using a microsquirt modul board 2.2 (case too small for an MS2) to build a PNP megasquirt for a French car.
That car is equipped (offcourse
My plan is to build an addon board using PT6/PT7/iac enable from the microsquirt.
I’m a car enthusiast and an industrial electrician but I’m not an electronic specialist.
Following the drawing from the MS2 I think it is strait forward
I have found supply of the microcontroller chip UDN2916LB
I will reproduce the set up from the MS2 board and wire PT6/PT7/IAC enable the same way.
I just need the confirmation of the resistor and capacitor I need to buy on the drawing.
R8/R7= 1 kilo ohm resistor?
C16 = 0.56 Farad ???? not milli or micro ?
C15/C13 = 0.1 Farad ???? not milli or micro ?
C14= 0.58 Farad ??? not milli or micro ?
R5/R6 = 1 Ohm 1 watt ????
Then I’ll build up the circuit and connect the processor and motor stepper controler
Iac Enble to Iac Enble
Pt6 to IAC1
Pt7 to IAC2
Vcc = what 5 volts ? from V ref ?
My last question is About the code.
I guess the code is unchanged and following the same steps than for a ms2 I can enable the stepper control
Thank you for you help
