Methanol fuel map
Anderson
Methanol fuel map
Post by Anderson »
Looking for a methanol VE fuel map for a 2.4 liter motor? Anyone have one :)
Re: Methanol fuel map
It's generally around 2.3 times as much fuel as an equivalent gasoline map. Usually just scaling the Required Fuel will get you the right fueling if you have a well dialed in map on gasoline. The spark table is another story, but it usually needs more timing.
