Good news to all those worried about cold weather, my car fired up right away.
(I know, I know, I'm not the first person to drive one in the cold, but I'm pretty excited anyways
Go Megasquirt!
Being due west across the border from Roger, I get pretty much the same weather. I like it when it gets this cold (!) because it let's me play with my ASE and WUE settings.On Mon, December 20, 2004 10:19 am, renns wrote: We're at about -22C here. Good news for the ice rink, though. It was just water two days ago!
Lee,MrSlick wrote:Eric... do you have any advice/theory on ASE/WUE stiings in general as far as temp, and low temp go?
Thanks for the info.njansenv wrote:Mr Slick... I can send you some info: I think my Neon engine is similiar 'enough'. My cams are pretty different, and I'm missing that turbine thingie on the exhaust side.![]()
She started Monday at -20deg C. I'm running 195% enrich in that area, IIRC. Even at 0, the enrich values are around 160 or so. 55% ASE for 150 cycles (?). I'll double check later, and post the numbers. I couldn't believe how much fuel a cold motor needs.![]()
I LOVE megasquirt.
Nathan
Well i'm going to try and finally get my MS 420A/2GNT install page together today... and see if I can get some ifles uploaded...boost junkie wrote:>>>I want to build a database of 420A msq files... ;)
When are you putting this database online? I could use use it when I try to start my car in the next few weeks.
