Eric - VexMe was leaning the maps before in the center as well - I will level out the map and repost after my run home from work - maybe i should not have started with the VexMe map. I should keep AE enrichment off for this excercise right?efahl wrote:Well, it sure is uglifying the map... It mostly appears to be leaning things out, but there is that one rich hump left of center at the back.WolfGTI wrote:Here's a look at the 3D maps before and after the first run with the autotune on.
Do the results look trustworthy to you? (They don't to me.)
Eric
Here are the maps I will restart the auto tuning with - my EGO correction step is set to 1 and the authority is set to +- 50%, the engine is 4cylinders, I have the ignitions events per step set to 16.
