surge tanks?
surge tanks?
http://www.sdsefi.com/techsurge.htm
steve
elansprint
http://www.nfauto.co.uk
Ian
steve
elansprint
I don't have the option of using a baffled tank for my Dart, at least not without spending a lot of money. I also didn't have many tools to build my own surge tank. So I'm using a trick that I learned on this forum. Here's a website about using a spin-on filter for a surge tank.
you could use a propane bottle from autozone or something but make sure you fill it up with water before you pop the saftey valve out
total project cost wil be 10 bucks for bottle and fittings
What I would do if I were starting over, is to modify my existing fuel tank to accomodate a conventional in-tank pump. Others have done this by cutting out the mounting flange from a tank at the wreckers, and having it welded to the top of the existing tank. This allows dropping a standard fuel pump assembly down into the tank. A small slosh pot is added inside the tank to surround the pickup to prevent starvation when cornering at 1/4 tank. Now you've got an 'oem' type installation, with a simple supply and return line to plumb up to the engine. Boy, just talking about it makes me want to go out and mod my tank...
Did the 280z's use an in-tank pump? If so, you might look at swapping in a tank from that model. BTW, love the 240's. I owned three of them years ago. They biodegraded very quickly in the Canadian climate, but were lots of fun till the frame rails let go!
Roger.
(of course!) injected 13B rotary.
jonfx4com
If you look here
http://www.fuelsystem.co.uk/new_page_8.htm
you will see that my HP pump holds 3 BAR at around 3 litres a minute but a facet competition LP fuel pump can only pump 35 Gals / Hour which is 2.6 Litres / Minute. Result is an empty swirl pot!
I suppose if you find a BIG LP pump it can be made to work but then your paying money to bodge the job when less money will do it right.
Jon
Jon
