Horrible idle + video
LRoy12
Post by LRoy12 »
i am using the standard code... i just downloaded the s19 file from here http://www.bgsoflex.com/megasquirtembdown.html
under "Download the MegaSqurt megasquirt.s19 File Here"
i flashed it onto MS using easy therm... is this the right firmware? :O
LRoy12
Post by LRoy12 »
well i disabled accel enrichment by setting the delta to 24, the car still acts the same. i have played around with the warm up.. changing te 60degree and 80 degree units to ~135% and it still wont budge.
my parents gave me the ultamatim of, "get the car running by monday night or else put it back to stock".
sooo, i checked my wiring to see if nything was wrong and it seems fine to me. I am using easy plice connections to connect most of my wires, and crimped connections. I dont think that there is a conductivity problem >_>
easy splice connectors ^^^
i dont know what's wrong, i have even based my settings of similar 16valve engines and it still idles horribly. hmmm
all i know is that i will keep trying because i do not want to go back to stock and have wasted all this week :shock:
LRoy12,
Looking at your datalog, it seems you are still dropping to 300 rpm or less at times, invoking the cranking pulsewidths.
So the next thing I think I'd do is open the throttle a bit more. There may be a screw stop for the throttle travel on the throttle body - screw that in a 1/2 to 3/4 turn. This will raise the idle, and keep you from going into cranking enrichment.
Once you have it running better (and not going into cranking pulse widths will make it *much* easier to tune the idle), and can tune the idle, you may have to turn the idle back down a bit.
LRoy12
Post by LRoy12 »
actually i have the screw almost all the way turned. i will turn it a wee bit more though, and even try turning it back
mops
Post by mops »
any progress ?
are you controling spark ? you might play with spark advance.
if you are letting in too much air then it's running ridicolously lean therefore idling rough.
