Smallest injectors available?
bigandy
I am just tossing a few ideas around at the moment for a large scale RC model glider tug (about 2.4m wingspan) that is going to be powered by a 45cc petrol engine. I am interested in converting the engine from a carburettor and magneto ignition, to something a bit more advanced.
Anyway, to cut a long story short, The only real bits that I am struggling with is the slection of an injector. Or to be more precise, I don't have a clue what smaller sized fuel injectors are out there! Does anyone have any knowledge of fuel injectors suitable for use with a smaller engine?
Any input would be appreciated, as would links to other resources etc etc. I've already emailed a few suppliers with no responses as yet, and I'm also settling down for a bit of research on the net now!
Cheers
Andy
the bubbler
Over the coming year or two, I think you'll start to see a big increase in the availability of small injectors and associated pumps etc.
This is owing to ever tightening motorcycle emission regulations leading to manufacturers developing small EFI systems for mopeds and scooters, in addition to their range for larger bikes.
Andy
efahl
- Site Admin
How much power does your airplane motor make? How fast does it spin? I'm guessing the high speed of the motor is going to require that your injectors be a lot larger than they would be for a motor of similar power running much slower. Andy Whittle has a spreadsheet that should help you out, I think it's on the Hi-Tech forum.
Your other big challenge is going to be finding a light fuel pump that can supply sufficient fuel pressure, and then suppling it with power... Bike parts are probably sized appropriately, but they are dense lumps, not really optimized for weight in the way aero pieces are...
Eric
H2Advocate
MegaBaro.
Came across an email msg, a guy was FI'ing a 17cc engine for an
economy contest. Said they used a 0 280 155 731 - 750, which he
thought was 75cc/min.
Putting into Google "60 * 6.5 * 75cc in gallons" shows 7.73 (lbs/hr)
My math is 75cc/minute times 60minutes/hour times 6.5lbs/gallon,
and let Google convert cc's to gallons, answer in pounds/hour.
BTW, they got around 650MPG, record is about 10 thousand.
regards,
phil
