How to wire Toyota 4A-GE Silvertop 3 Pin PWM to MSII V3.0?
jamesawooten
I'm in the process of wiring up my 4A-GE Silvertop into an '86 MR2 using MSII and the V3.0 mainboard.
The MSII manual seems to be a little vague on wiring the 3 wire PWM idle valve that I have (picture attached) to the DB37 connector.
The wires are (left to right) w, b/r, w/gr.
Any help here?
Regards,
Jim Wooten
[/img]
rb26dett
rb26dett
jamesawooten
jamesawooten
hbtorana
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135247#135247 -------------------- m2f --------------------
Posted by email.
hbtorana
toyota 4age/4agze 3 pin valve
Denso sent a (toyota) pinout. They are not willing to provide any further info.
The valve is partially open eg 1/3 from factory.
The pinouts as follows:
The r/siscv upside down with three tabs to the sky.
Left to right
isc1 "Close"
b+ 12v (but can definately range between 9-12V)
isc2 "Open"
The valve/vane is fixed in relaition to shaft.
So it cannot be used as a straight on off.
the r/siscv is also used for carbon canister/vapour purging.
Could potentially replace it with a flat plat, taps and and egr valve from a blue top....
My gze is in a 69 torana
(8-11 gallon fuel tank, does not require carbon canister)
hbtorana
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135248#135248 -------------------- m2f --------------------
Posted by email.
hbtorana
iac toyota 3 wire
SAE paper "j pin voltage chart" for the toyota.
isc0 and isc1 with ignition on 9-14v
if you have an seperate air con iscv (eg on blue top or celica)
-- 9-14 no air con,
with air con 3v max @ idle
hbtorana
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135249#135249 -------------------- m2f --------------------
Posted by email.
