lpg system control from MS? can it be done with stock code?
Just my 2 cents...
EFI maniac, BMW fanatic
- '84 BMW 528i I oughta squirt...
Phillblanchard
Ive been mad busy since i last posted on here and basically want to thank you and the others on here for the ideas and help
the rangie is running fairly well, i hadnt fitted a volume restrictor in the gas line from the reducer, so it was dumping a shitload of gas into the engine!! lol
wondered why the milage was so crap!
anyhow, i fitted one and got it running more econo mode style (10mpg around town).
think ive got it pretty much sorted now, the only gripe is performance.
when cold, and on petrol, it goes like a missile!! on lpg and cold its very moderate.
when warm, performance on either fuel seems worse again. not lots worse, but you do notice the difference.
maybe need to tweak the mixture a little on MS. Can i use the lambda to tune in the lpg? in the normal 0.5v cross over way or do i have to run it richer?
im currently running 10 degs advance too.
Regards and much thanks,
Phill
3,000 rpm . No load on the engine .
Then make adjustements to the restrictor to find the oxygen sensor
stoich point . Trip point at 0,5V with a narrow band .
You can watch the gauges in megatune to .
Next take it on the road , 3,000 rpm at cruising speed .
Look at the oxygen sensor again and adjust the volume restrictor
to the toggle point. This could take several runs to find it ,as you can't adjust the restrictor while driving , can you .
When you've found the trip point , adjust the restrictor 1/8 to 1/4 turn to the rich side . That ought to get you a decent performance vs fuel economy .
Pat
