Neat! I didn't know you could do that!ETECH wrote:Hi,
Just a tip:
With the advanced settings of the LC-1 you can program what voltage it outputs during warmup or error. You can program that to be some safe value.
Regards
That would work great for the MSI where you cannot set target AFR. I'd just program it to tell the MS the A/F ratio is 14.7 during startup/warmup.
I suppose I could do something like set the target AFR to 14.7 across the board...get the tune close with autotune, then start messing with the target AFR stuff while turning EGO authority down to something like 10%.
