Duty Cycle Spike?
m0ntecarloss
Yes, that's right - low numbers slow the response, high numbers speed it up. 100% is no lag at all. There's more on this here: http://www.megasquirt.info/ms2/configure.htm#lag
It's hard to say exactly what is the threshold for too slow, but I'm sure you'll know it when you get there... Certainly in most cases 50% should be fine, and even considerably lower will probably work for most people, most of the time.
m0ntecarloss
No I apologize, I should definitely have experimented more before posting. I only get to play on the weekends and unfortunately the vehicle is not here for me to check this out. I'll post later if someone else doesn't get to it first. I had not thought about the lag filtering..lance wrote: Has anyone experimented with the input signal lag factors to see if this is related to spurious input signals that are too quick for the datalog to capture?
mops
- Experienced Squirter
ah, you are tEh sHiZ !!!lance wrote:exact same thing for me - 32ms pulse width for one instant....
m0ntecarloss/wes kiser/mops,
i'll try it out tonite and see "huh" is going on
mind you... i never seen a spike on my datalogs
just at some rpm/map my engine oscilates between ~11 and ~16 afr for no aparent reason.... (with ego corr disabled... ego corr makes it even worse...)
oh, um.... abouther question.
I'm not using dual table, shich means that I use single table only. however in my logs PW1 and PW2 are different... they follow close together but often +-10% different.... is that normal ??? does PW2 have any meanign in my case (as i use single table only) ?
Something else I tried was unplugging my map sensor, and seeing what happend (car off). The map spiked up to over 200kpa, and then slowly bled down to the 150 range before I plugged it back up. So this means any hardware problem that could cause no map signal could cause this. Because of the magnitude of the spike, the only signal that I think could cause it (as a response to an input) is the map. I understand this could be anything from my sensor ground to an interupt to the 5v vref, to anything in between.
I will keep the lag factor low and see if the problem stays away.
Again I reitereate I have not seen an input out of line, simply speculating that the only input that could shoot pulse width up that high is the map spikeing way high (enabling my max mapdot value, in addition to the obvious 200 plus kpa).
mops
can anybody confirm ??
