Yeah, I can't find any solder problems either. Did you assemble your MS yourself?DGFTurbo wrote:What pads were bridged? Im having the same problem and i cant find any bridged pads.keithmac wrote:Only problem I had was the solder pads contacting each other (bad soldering), you shouldn`t ever see 5v out of the pin, just gound when the fuel pump output is active. The Processor output is 5v, sounds like something`s wired in wrong on the board..
Fuel pump is constantly running
Turbo Corolla, soon to run on MSnS
So, you fixed your problem? And you were having the same problem? 5V out anytime the MS is powered?keithmac wrote:2 pads on the fuel pump transistor were (just) bridged with solder, I didn`t assemble my board either..
First step would be to replace the fuel pump transistor and check it`s orientation I would have though?
Yes I didturboyota wrote:Yeah, I can't find any solder problems either. Did you assemble your MS yourself?DGFTurbo wrote:What pads were bridged? Im having the same problem and i cant find any bridged pads.keithmac wrote:Only problem I had was the solder pads contacting each other (bad soldering), you shouldn`t ever see 5v out of the pin, just gound when the fuel pump output is active. The Processor output is 5v, sounds like something`s wired in wrong on the board..
What transistor is the fuel pump circuit?
