predictor algorithms
I had been having low rpm missfires, tach jumps, and detonation at boost onset around 3000 rpm even with drastically reduced timing. Changing the predictor algorithm fixed it all.
I think we definately need to play with this parameter more to find out what is ideal for different setups.
daniel505gti
Philip Lochner
Re: predictor algorithms
Last interval and 1st derivative seems to work fine.
1st High and 2nd derivative definitely results in poor idle.
Philip
Philip Lochner
Since my previous post on this subject I've had my car on 1st Derivative as I thought that worked as well as LI (or better??), even at idle, and it does, UNTIL I SWITCH THE AC ON. That additional load somehow upsets the algorithm and results in really bad idle with much reduced RPM with unstable AFR. Opening throttle a tiny bit settled things down (this is where RPM based IAC could perhaps help) but I could not get my AFR at idle better than 13.
With Last interval, I've managed to get AFR up to 14 and ROCK STEADY. Idle RPM is also rock steady at 10BTDC and when the AC kicks in, Ive set my timing table so timing goes to 17BTDC (due to increase in MAP) and AFR is still steady at 14. Idle speed only drops by 50rpm or so
Philip
