MSII vs. MSD for ignition
ChevelleFan
Post by ChevelleFan »
If I end up having trouble with them so closely mounted, I'll be sure to let everyone know.
-Dave
'70 Chevelle, MS-II/406 Stealth Ram/TH350/3.55
My success story
12.94 @ 106
twotyerfryer
Post by twotyerfryer »
I was thinking about placing the MSD just below the MS-II - Steve
'88 Mustang 2.3 turbo
MSII V.3 MSD 6AL
wagon
Post by wagon »
That setup in the photo looks good - I would try and keep a small distance between the msd and ms cables. For example, I have seen a car with a conventional reluctor dissy misfire and carry on because the wires from the reluctor in the dissy were routed next to the ignition coil leads - the ignition module was getting false triggers from the noise. The problem went away after the wiring was moved. (It happened on 2 cars - 1 was an old carby RX-7 and the other an efi-converted-to-lpg range rover V8.)
