bouncy idle
MegaScott
- MegaSquirt Guru
On one of my cars, with the OEM ECU it idles at 1200rpm, I put Megasquirt on it and it idles like a dream at 900rpm. Go figure.
I've been trying to tune idle for minimum map, sometimes I can get it down around 38kpa, but it doesn't seem especially steady.
I adjusted my Accell Enrichment, it's very odd the way the TPS rate behaves. The default max rate was 154%/s, but I found I could only get about 20%/s by flooring it immediately. A more reasonable throttle 'goose' is like 2%/s. I cut all the rates down ten times, and I was able to actually get throttle gooses that raced the engine rather than stalling it.
I'm concerned for a couple reasons, for one, it sounds like it might be missing a cylinder sometimes, other times it sounds pretty smooth.
Another thing is that CLT is getting pretty high, this might be related to the fact that I don't have the fan blade attached to the fan clutch... Ishould probably put that back on, huh.
Here's a new datalog of me getting it started and idling halfway ok, then trying to get it to race in the 2500rpm range and smooth it out, with a small amount of success.
MSII 2.36, v3 board, MT 2.25
have a lookseee... the first couple TPS spikes, you can see the Gve go through the floor, so I richened up the low-MAP bins above idle RPM, and was able to get it to smooth out in the 2k-3k range..
Is it ok that it's running so rich? I'll pick up an LC-1 from Jerry pretty soon hopefully
Anyway, I'll smooth out the table above no-load map bins, and tomorrow night try to drive it some.
Stock S130/Z31T 260cc injectors are low imp. Are you sure yours are high imp?tmbg wrote:they're high impedance injectors, 260cc on a 3000cc engine, REQ_FUEL is set to 12.9, idle VEs are around 25.
It seems like it's running very rich, but I'll try playing with the ASE and WUE.
I guess I need to go get that LC1 I've been wanting.
Refer to http://www.redz31.com/pages/fuel.html for more info.
