Posted: Tue Jul 11, 2006 1:20 pm
What I was saying is with that little plastic tank setup, blowing through the lines won't tell you anything. We did the same thing and it lies because of how the tank works.
But obviously your on the right track if its running at tickover.
Because of the way that tank works, I would eliminate it ESPECIALLY with the turbo setup! What its doing is its returning fuel into that small tank instead of the fuel tank. That tank ALSO feeds the main pump. Only when the engine is returning a lot more fuel does it "overflow" and return fuel to the main gastank. If your lines are still going across the firewall over to the drivers side, its going to REALY REALY exasberate the issue and cook fuel, then feed it right back into the main pump.
Get your lines off the firewall if they are still there. Or at least use a metal sheild and then something like dynomat heat reflecting sheild overtop of it. My turbo has gotten hot enough to cook brake fluid in those lines... I have an 8v turbo setup in my cabby, I imagine yours is even tighter and hotter.
