I can not get a tach signal with my MS-2 using a GM DIS syst
I think I have my crank rpm set to 300 or 350. Whatever it was set at stock was too low. It just wouldn't fire anythig other then a prime pulse until is was in cranking mode. I found that it didn'tlike to go into "cranking" until is was around 50-100rpm within that cranking rpm range. It could just be my car being "special" though.
Does your tach needle bounce when you crank it (the real tach in the cluster)? If it normally bounces when you crank and its not now, its usually a bad crank position senor.
jsmcortina
- MegaSquirt Guru
It is normal to have a setting more like 400rpm02z24sc wrote:My tach never did bounce when it was cranking. My cranking rpms was set
at 50, should I bring it up 100 or more?
James
