TFI wiring...Spout
joekamm
Re: TFI wiring...Spout
Post by joekamm »
Matt, I will try resistor change tomorrow
joekamm
Post by joekamm »
I changed the resistor to 120 ohms. no change. The engine still starts right up with spout out. Tuner studio shows good MAP good rpm . I ran trigger wizard to sync distributor and ecu . Shows variable spark advance as if the table is being calculated for the running engine parameters. I am using the spare port for wled (pm5) reassigned in the software to Spk A. Not sure what the other parameters in that window should be set at but I have Enabled checked power on value ON active value ON rpm > 100 0.0 hysteresis no additional conditions.....(pm5) should output through pin 17 for microsquirt and I am wired to pin 17. I feel I am missing some setting somewhere and it is getting frustrating !
joekamm
Post by joekamm »
abandoning tfi project. maybe the whole project.
