Page 2 of 11
USB to Serial Adapters
Posted: Wed Sep 22, 2004 12:53 pm
by hookem2oo7
using the keyspan usb adapter from compusa...pricey ~$40, but have had absolutely no problems datalogging/tuning/updating/etc...
Posted: Wed Sep 22, 2004 11:17 pm
by Skiericski
Update... Still using the Belkin PDA adapter. I haven't had any more comm trouble since switching to the latest megatune 2.25 version.
Posted: Wed Sep 22, 2004 11:22 pm
by Skiericski
Posted: Thu Sep 23, 2004 5:52 am
by miked
Looks like the Belkin # for the "PDA Adapter" is F5U109 and its MSRP is $29.95. with a street price around $25.
The compusa part
is here
StarTech Computer Products makes a 2 port PCMCIA serial port, pn CB2S650 for about $55
Posted: Sat Oct 02, 2004 1:22 pm
by eliotmansfield
I too have the Blue "prolific" usb adapter and was also getting problems sending the enrichments page using msns-enhanced.7 - I could get round the problem by saving in another page such as tuning.
Tonight, ive just upgraded my spare MS to MSnS-Extra020 with MegaTune 2.25-b271 and still get comm errors when i try to send the enrichments page - constants page sends ok.
Also it appears that i get errors sending VE tables now that they are 12x12 im sure when they were 8x8 it was ok before.
Using IBM Thinkpad t41 & WinXP sp1
Posted: Fri Oct 15, 2004 5:53 pm
by brickster151
I'm having a little problem with this, I've got 1 serial port on my new labtop and need two, one for MS and one for my WBo2. Will a USB to Serial Adaptor be able to send enough info for a WBo2? Whats the best solution?
Posted: Tue Oct 19, 2004 7:40 am
by Bimmerjim®
my labtop is very elderly. the only conectors on the labtop are a DB 9 female, a db 25 male, and a db 15 male....... an RF sensor, and aidio in and out mini jacks
can anyone suggest to me a method of conecting my labtop to my pc? iv heard a db 9 male to male cable will not work.
Posted: Tue Oct 19, 2004 8:34 am
by Skiericski
Do you mean to connect your laptop to your megasquirt? Connect your DB9 to the DB on the MS box with a straight through cable.
Posted: Tue Oct 19, 2004 10:03 am
by MegaScott
Bimmerjim-
Not sure what this has to do with your MegaSquirt, unless you want to transfer your megasquirt stuff from your pc to your laptop.
The best way (for me) to connect two computers together is through a network connection. most all laptops have a PC card slot right? get a cheap pc-card network card for your laptop with a 10/100baseT RJ45 connection. Get a network card for your desktop pc, if it does'nt have one already. Hook together the two with a CROSSOVER network cable, you can get one of these at most all computer stores. This will connect both pc's together and will communicate via micro$oft networking for simple file transfers. Just make sure that each pc has its own compatable TCP/IP address.
You can use the parallel port to transfer files with windows XP, or with file transfer software in 9x, you need a special "File transfer" or "laplink" (hint) style cable.
You can also use the serial connection to transfer files, it's alot slower, but it works, you need a "null modem" cable or adaptor, and best to use SLIP for Machine to machine transfers. If you have terminal software running on both ends, than you can direct connect and use a binary file transfer protocol like x, y or z modem. Most pc's have this built in (hyperterm) personally I still use my 10 year old copy of Telix for DOS.
http://www.telix.com
USB comes in three flavors, USB 1.0, 1.1 and USB 2.0, if you have USB 1.0 you can transfer at least 1.5megabits per second (Mbps) through the port, now considering that most serial connections are from 2400bps to 115kbps (9600bps is most common) you should have no problem with speed on a USB to serial adaptor. The biggest problem comes when setting up your com program, you need to be able to set it for the com port which your USB to Serial connection driver is using. some USB-serial devices only allocate com 5 and higher, some will allocate any com port. So as long as you can match up the com port in your WB O2 software, with the com port of your USB-serial connection, you should be fine.
BTW- USB1.1=12Mbps USB2.0=480Mbps This is the maximum total throughput per port, your actual speed will vary based on CPU load.
S.
Posted: Tue Oct 19, 2004 10:43 am
by Bimmerjim®
MegaScott wrote:Bimmerjim-
USB comes in two flavors, USB 1.1 and USB 2.0, if you have USB 1.1 you can transfer at least 1megabits per second (Mbps) through the port, now considering that most serial connections are from 2400bps to 115kbps (9600bps is most common) you should have no problem with a USB to serial connection. The biggest problem comes when setting up your com program, you need to be able to set it for the com port which your USB to Serial connection driver is using. some USB-serial devices only allocate com 5 and higher, some will allocate any com port. So as long as you can match up the com port in your WB O2 software, with the com port of your USB-serial connection, you should be fine.
S.
thanks.
thats exzactly what i need the conection for. is to conect the laptop to the home pc. the way i get data onto the laptop was by burning a cd with the software i need from my desktop pc and installing it off that cd onto the laptop, but id like to be able to upload my datalogs from my laptop to my desktop pc. i think my laptop has a slot for a network card, but no network card is present. i was just looking for a way using the things that are on the labtop already.
