Dwell calculations
Flatline_Racing
L=9.5 mH
R=1.55 Ohm
I have input several values of I. Here are the corresponding values for T.
I_______T
(amps) (ms)
1______.85
2______1.83
3______3.00
4______4.46
5______6.36
6______9.14
7_____14.37
7.7____32
How do I decide which pair of I and T is the best to use?
I graphed it in Excel, but there is no obvious point of inflection on the curve.
And for future reference, what is the right way to put a simple chart (like the one above) into a post?
Thanks for your help and advice.
- Site Admin
For this coil it appears to have a slow charge time. You want a primary current around 5 - 6 amps before spark, but this leads to a dwell time of close to 9ms which will limit your upper RPM. You may want to see if 4 amps (4.5ms) works for your setup..Blue wrote:I'm trying to use Bruce's formula to compute the dwell setting for my ignition coil. Here are the values for my coil.
L=9.5 mH
R=1.55 Ohm
I_______T
(amps) (ms)
1______.85
2______1.83
3______3.00
4______4.46
5______6.36
6______9.14
7_____14.37
7.7____32
BTW, your chart was fine
ajay magge
