Yeah I found it helped alot too to get more accurate static timing.busta9876 wrote:Last interval has help a lot! I've been out driving for about 3 hours tonight using autotune and a little MSTweak. I just need to enrich the high load areas a bit and lean out the cruise parts and I'm done. I sitll need to tweak the timing a little but the engine seems to be running pretty good now.
Have you just been working on mapping the VE table or started on the enrichment side of things yet? One thing i've been trying to get right is the injector opening time. I found the default 1.0ms seems to be ok, but there is an equation in the tuning fuel & air forum that shows how to mathematicallly work out your opening time with pulsewidth and amount of squirts... I calculated about 1.1ms should get me in the ballpark, but I cannot swap from 2 to 4 squirts and not have it want to die on me.
Ohwell it turns out I have a bad alternator, the minute the fans cut in and start blowing hot air over it, it will discharge until the car stops. I know it's not the fans as I can disable the fans afterward and it will still discharge about 11.8V-12.2V, i.e. run off battery. I let it sit for about 4 hours, fire it up again and bingo, 14.4V.... A new diode pack may help but i'm not so sure as i've replaced the regulator twice...
God this hobby is fun!!!
