Posted: Sun Jul 30, 2006 1:53 am
I don't know if you'll get a very steady MAP reading from a V-twin so connecting the FPR to MAP may or may not be a good idea. The difference between 60kPa and 100kPa is about 6 psi which is a fuel pressure difference of around 11%, not a real lot of change, but if your MAP is all over the place so is your fuel pressure maybe - meaning the MAP is continually pulsing on a V-twin, I don't know how that would affect your fuel delivery (fuel pressure) because I haven't tried it. People have used variable orifices and plenum chambers to smooth the MAP on these motors with success, so that's an avenue too. The Buells don't reference the FPR to MAP, but at the end of the day, wire it all up and plug it all in and see what happens, then if something gives you some issues you can fix it, often the things that you think will be an issue turn out OK, but it's other unforeseen things that can cause issues, but you won't see them until you get it fired up. There's a lot of support on this forum if you have any probs.
Ian.
Ian.
