Setting up an initial ignition timing table
AFR table generator perhaps?
Or maybe it could be derived from an existing VE table? Is the VE formula close enough to derive AFR's, or it should be derived by another interpolation method?
EFI maniac, BMW fanatic
- '84 BMW 528i I oughta squirt...
Leistung Elektronik
Hi Lance,lance wrote:
Finally, for boosted engines, you subtract 0.3° of advance for every kPa above 100 (it's not a coincidence that this is the same factor as for the 'vacuum' adjustments). Because 101.3kPa=~14.7psi, this works out to ~2° per pound of boost. It is often the case that you want to limit the retard under boost as well, typically so that it takes out no more than about ½ of the maximum advance at 100 kPa.
I don´t understand because you substract to much advance degrees when the engine ist under boost. We run a 1.6 L Fiat engine under 30 PSI of boost with 22° final and no detonation. What ist wrong?? Have you considered any CR (9:1 ; 10:1 ; etc) ?
I apreciate your help, because i´m trying to find a simple metod for make a start advance table for boosted engines.
Fiat 1.6L Turbo @ 30 psi - MSnS Extra whit CDI
soon Ford 2.5L Turbo
IAT and timing
Is anyone working on adding this ? (why or why not ?)
I've heard rule of thumb there is -1 degree per every 10 degrees above 120.
mad max
http://www.innovatemotorsports.com/resources/myths.php
msnse1.6l sohc 16v turbo suzuki samurai http://www.msefi.com/viewtopic.php?p=116468#116468
msnse1.3l sohc 8v suzuki samurai (fuel only daly driver)
msnse1.3l dohc 16v suzuki samurai
2xmsnse1.3l dohc 16v swift gt
Leistung Elektronik
TT350chevelle
http://www.microsoft.com/downloads/deta ... laylang=EN
Try http://www.OpenOffice.org. OpenOffice is a free office suite that appears to handle this MS Office spreadsheet.burgo90 wrote:yes i downloaded that but its only a viewer so i cant put my own values in to create my own table
