no go
tomf757
cont'd
Post by tomf757 »
pw =4.2ms
the word should have been can instead of car
Tom757,
You need to go back to the link I posted, and look at all the tips there, and let us know what's happening on each one, not just the ones I used as examples.
You also need to post legibly, I doubt many people are going to try to wade through ALL CAPS embedded in a quote (at least I won't).
If you need to verify that your MegaSquirt works, you can either send it back to whoever built it to do that, or you can purchase a stim.
tomf757
yea, yea
Post by tomf757 »
i should go and drive it washington as i need the vacation...oh wait the car wont run with out fuel my bad
renns
Post by renns »
It's not good form to complain about lack of support on a forum staffed by volunteers. I'd suggest you contact your vendor for further support. Who knows, maybe he'll take the unit back for return, repair or replacement.
Roger.
tomf757
thank you
Post by tomf757 »
I am trying to contact that person now. I just got the unit back after he worked on it for four months. I would like someone else to look at it, but if I have to send it back I will.
I really appreciate your input.
Tomf757
MegaScott
Re: yea, yea
Post by MegaScott »
tomf757 wrote:i should go and drive it washington as i need the vacation...oh wait the car wont run with out fuel my bad
Where do you live?
When you say "car " what make and model? there's a lot of "details" you are intentionally? leaving out.
Have you wired up the Megasquirt as per the diagram in the Megamanual? Sometimes it helps of you get a second set of eyes to look over your wiring.
I realise all this sounds familure, but I read this thread from front ot back and I have not once read that you actually read the Manual and wired it up as per the recommended diagram.
The fuel pump relay is there for your safety, just hooking a switch to it is unsafe and can ruin your motor.
tomf757
Reply
Post by tomf757 »
I have read the hook up in the mega squirt manual, and have had a mechanic look it over. The engine is a A12 Datsun engine 1970 vintage. It happens to live in a 1975 Triumph Spitfire.
The fuel pump wirring is done this way because the vendor could not fix the mega squirt wiring when I sent it back to them.
I feel that the unit has "gone South" on me.
I can not get the vendor to respond to me and therefore I am asking for assistance from someone who would enjoy this challange for pay. (negotiable)
I am running a Renault Alliance TBI with Rochester injectors with low impedence injector.
The car does want to run with gas, but I can not figure out the issue with this unit, as I have mentioned any and all help is welcomed.
Thank you for your reply.
arnold
Post by arnold »
I might be able to give a tip: I had the same problem, using one injector in a TBI unit, also Rochester injector. It was some time ago, but if I remember well I solved it by using BOTH earth connections (#32 & 33 or / and (34 & 35), not just one... If you use one there is not enough power to open the injector
Hoep it helps :?:
tomf757
thanks
Post by tomf757 »
I'll give that a try.
Tomf757
tomf757
going going gone
Post by tomf757 »
good bye all mega squirters if anyone want to buy this and have spare parts I'll negotiate a fair price. otherwise it is out of here forever.
