Page 7 of 8
Hmmm..
Posted: Sun Jul 09, 2006 12:30 pm
by superelbert
CHB wrote:do you all think this map will work on my 3TC?
To me, that MAP looks a bit up-side down.. least advance at low manifold pressure in thstead of the other way around???
High vacuum = high advance :!:
Posted: Sat Jul 22, 2006 5:28 am
by Ferret
Some time ago somone (ones?) posted excel files that generate initial ignition maps.
My HD crashed and I lost these files. I can't locate that thread (deleted?).
Can somone please post these files?
Avner.
Posted: Sun Jul 23, 2006 1:33 pm
by Jon k
Yeah uh, where'd all the files go?
Posted: Mon Jul 31, 2006 9:01 am
by Jon k
Anyone?
Posted: Wed Aug 09, 2006 6:41 am
by juls
I had to log in before i saw the excel files in the first couple of pages.
I used one just then to generate my ign map.
Posted: Thu Aug 10, 2006 7:39 am
by Jon k
juls wrote:I had to log in before i saw the excel files in the first couple of pages.
The file posting is back up :)
factory ignition tables
Posted: Wed Aug 16, 2006 2:52 am
by Neno
lancia delta integrale 2.0 16V turbo
pictures are from http://www.rplab.co.yu/
Posted: Wed Aug 16, 2006 2:59 am
by Neno
ford sierra cosworth
Re: factory ignition tables
Posted: Wed Aug 16, 2006 9:44 am
by PSIG
Neno wrote:factory ignition tables
Could they be thrown together just for screen shots of the tuning program? Those do not look like typical factory maps to me. :? They look a little screwed-up even. Timing is pulled way before boost onset and there is no 'cruise' timing built in to the low load areas from what I can see - although I'm not used to reading maps in that configuration. I'd be careful if you use them as the basis of a new map until you can verify applicability.
David
Posted: Wed Aug 16, 2006 12:38 pm
by Neno
David
I think that they are definitly original ones because they were extracted from the original CPU.
This is only the basic timing map. There are many modifiers. You can download the pictures from that web site. There you will find screenshots of the entire program. Also there is an e-mail so you can contact the autor of the program for more detailed information. Unfortunatly the program is not open-source :(.
