Everything there is to know about MegaTune Auto-Tune
MegaScott
- MegaSquirt Guru
; Add your customizations here, they will be read at the end of the
; standard megatune.ini processing and override any settings there.
[AutoTune]
table = veTable1Map ; Should be the map3d_id of a TableEditor entry.
allowAutoTune = on
corrector = egoCorrection
; Vertex tolerance parameters
xRadius = 200 ; RPM
yRadius = 7 ; MAP
; Tuning block parameters
xLimits = 1500, 4000 ; RPM
yLimits = 60, 90 ; MAP
zLimits = 10, 200 ; VE
; Controller parameters
initialStartupInterval = 1.0 ; seconds
updateInterval = 1.0 ; seconds
proportionalGain = 0.5
lumpiness = 5 ; percent
efahl
- Site Admin
Enzo,enzo wrote:i got this message
"Auto-tune: Tuning point outside window"
what does it mean?
In this last revision I added two diagnostic messages to tell you what is going on with the auto-tune algorithm when it is turned on, but isn't doing any tuning. They are
which indicates that the operating point has gone outside the global x and y limits, so the no action will be taken. Likewise
Auto-tune: Tuning point not near vertex
indicates that the operating point is inside the global window, but it is not near enough a vertex (as defined by the "radius" parameters), and so no action will be taken. These messages are intended to help you figure out why the algorithm is not changing a vertex on the table, and allow you to modify the xLimits, yLimits, xRadius and yRadius parameters accordingly.
Eric
whittlebeast
bcrx7
http://www.not2fast.com/megasquirt/mt/prerelease/
whittlebeast
Andy
T3Bunny
She runs!
efahl
- Site Admin
Jamie,T3Bunny wrote:Will there soon be a menu interface for configuring this inside the MT itself as opposed to in the custom .ini?
That's a problem. All the other data that MT displays in dialogs for you to edit is stored somewhere inside your MS; the tuning parameters for auto-tune are just MT-specific data and really have nothing to do with MS... This means that I need to write something to re-write the ini file, where all this data originates and is stored, in order to have a slick interface on it, and thus far that program is called the MegaTune Configurator. Until I add some sophistication to mtCfg, you'll have to edit the custom.ini to effect changes to the tuning algorithm's parameters.
Eric
