Page 8 of 13
Posted: Thu Sep 15, 2005 2:07 pm
by enzo
i got this message
"Auto-tune: Tuning point outside window"
what does it mean? i'm testing it on the stim.
regards
Posted: Thu Sep 15, 2005 2:51 pm
by MegaScott
When you put it in the custom.ini, put it under the note that says so. Example-
; Add your customizations here, they will be read at the end of the
; standard megatune.ini processing and override any settings there.
[AutoTune]
table = veTable1Map ; Should be the map3d_id of a TableEditor entry.
allowAutoTune = on
corrector = egoCorrection
; Vertex tolerance parameters
xRadius = 200 ; RPM
yRadius = 7 ; MAP
; Tuning block parameters
xLimits = 1500, 4000 ; RPM
yLimits = 60, 90 ; MAP
zLimits = 10, 200 ; VE
; Controller parameters
initialStartupInterval = 1.0 ; seconds
updateInterval = 1.0 ; seconds
proportionalGain = 0.5
lumpiness = 5 ; percent
Posted: Thu Sep 15, 2005 6:22 pm
by efahl
enzo wrote:i got this message
what does it mean?
Enzo,
In this last revision I added two diagnostic messages to tell you what is going on with the auto-tune algorithm when it is turned on, but isn't doing any tuning. They are
which indicates that the operating point has gone outside the global x and y limits, so the no action will be taken. Likewise
Auto-tune: Tuning point not near vertex
indicates that the operating point is inside the global window, but it is not near enough a vertex (as defined by the "radius" parameters), and so no action will be taken. These messages are intended to help you figure out why the algorithm is not changing a vertex on the table, and allow you to modify the xLimits, yLimits, xRadius and yRadius parameters accordingly.
Eric
Posted: Thu Sep 15, 2005 7:11 pm
by whittlebeast
Did anyone get a copy of MT 621 before Erics server crashed? PM me if you would please.
AW
Posted: Fri Sep 16, 2005 12:36 am
by enzo
Eric thanks for the explanation!
enzo
Posted: Sat Sep 17, 2005 2:30 pm
by bcrx7
whittlebeast wrote:Did anyone get a copy of MT 621 before Erics server crashed? PM me if you would please.
AW
You can download 623 from the download section on this site.
Posted: Sat Sep 17, 2005 2:43 pm
Eric's site is back up now. MegaTune is at:
http://www.not2fast.com/megasquirt/mt/prerelease/
Posted: Sun Sep 18, 2005 5:08 pm
by whittlebeast
We did some testing with autotuning with the Honda this weekend with very positive results. Eric and I are doing a little fine tuning on the settings and this feature should be ready for prime time very soon. More info to follow soon.
Andy
Posted: Sun Sep 18, 2005 11:00 pm
by T3Bunny
WOW, I am IMPRESSED! I can't wait to try these goddies out now! We finally have the wideband setup and installed and ready to go play! Will there soon be a menu interface for configuring this inside the MT itself as opposed to in the custom .ini?
Posted: Mon Sep 19, 2005 7:30 am
by efahl
T3Bunny wrote:Will there soon be a menu interface for configuring this inside the MT itself as opposed to in the custom .ini?
Jamie,
That's a problem. All the other data that MT displays in dialogs for you to edit is stored somewhere inside your MS; the tuning parameters for auto-tune are just MT-specific data and really have nothing to do with MS... This means that I need to write something to re-write the ini file, where all this data originates and is stored, in order to have a slick interface on it, and thus far that program is called the MegaTune Configurator. Until I add some sophistication to mtCfg, you'll have to edit the custom.ini to effect changes to the tuning algorithm's parameters.
Eric
