Injector Positioning - Max distance from intake valve
Posted: Thu Oct 06, 2005 10:42 pm
Gentlemen,
Can anyone offer any information on this?
What's the longest distance people have used for injector positioning relative to manifold face (or intake valve position) that has been fine for cold starting with no form of heating for the intake? If you do put forward an answer on this can you say what engine size you are using, cranking speed and a few notes about your intake shape/design.
I'm not talking about having a second set of injectors behind the butterflies here, purely the distance from your closest set of injectors.
The wet manifold I am using is not working out great for cold starting. I'm still playing with pulsewidths a little but it's a battle between too much fuel for the small cranking airflow to carry and liquification on the port/manifold runner walls.
Just wanted to see how other people's setups compare. Anyone got a heater anywhere?
Cheers
Dan
Cheers
Dan
