Acceleration Wizard
Posted: Sun Nov 06, 2005 10:23 am
by Mad Professor
Hi All.
Just me again.
I have read over the MS online manual, and I still have no idear what i have to do in this bit.
At this point in time I have no TPS.
Can anyone please help me with the settings here, as i have no idear where to start.
Thanks for your time, and support.
Posted: Sun Nov 06, 2005 10:30 am
Mad Professor,
If you have no TPS, then you need to use the MAPdot accel erich function, which is built into MSnS-E and MS-II.
The basic idea with TPS based accel enrich and MAP based accel enrich is the same, it's just that MAP based accel tends to come in sooner and not last so long, so it's needs to be a bit closer to the ideal tune.
There's an outline of the tuning procedure here:
http://www.megasquirt.info/ms2/tune.htm#accel
Posted: Mon Nov 07, 2005 6:01 am
by Mad Professor
Still have no idear.
Bit of help here please.
What i need to do? :oops:
Posted: Mon Nov 07, 2005 6:20 am
by karlo
At present, don't bother with the acceleration enrichment at all, just disable it. Your car will most likely be driveable without it, but you may experience bucking when you floor the pedal.
Once you have the car running fine and fairly well tuned in, you can move on to AE.
- Karl
Posted: Wed Nov 09, 2005 8:15 am
by Mad Professor
Do I not need to have the "Acceleration Wizard" settings right for the car to start & idle?
Posted: Fri Nov 11, 2005 8:39 am
by boost junkie
No. Acceleration enrichment is for, well, acceleration. IE when you stab the throttle.
Posted: Fri Jan 06, 2006 7:10 am
by Mad Professor
Hi All.
At long last I have got a TPS fitted and wired up.
I still have no idear what I am doing with the "Acceleration Wizard"
I am running MS-II pcb v3.0, MS-II Code 2.1, MegaTune 2.25b731beta.
Can anyone please help me set this up?
Thanks.
Posted: Fri Jan 06, 2006 7:21 am
by Mad Professor
I've just uploaded a Datalog & Setting file.
datalog200601061449
megasquirt200601061451
I don't know if thay will help at all.
Posted: Fri Jan 06, 2006 11:57 pm
by Mad Professor
On my datalog is am still getting alot of noise from somthing, I all ready have a noise filter on the alt, But that dose not seem to of done anything.
I think I am going to disconect the wire from the alt, and see if the noise go's away.
