need help to tune singles
zuelkhairiey
Post by zuelkhairiey »
hi i'm a newbie here
i have just finish installing my first ms on my 150cc single motorcycle :)
i'm using msns extra 024s13 code
the engine starts and then died a few minutes later
i have attach the datalog and hope someone can guide me on how to tune
i'm currently using speed density algorith and havent try using alpha-n yet
also the rpm reading is not the same with the rpm meter.either i tap it from the coil or a sensor in the engine
hope u all can help
78Spit1500Fed
Post by 78Spit1500Fed »
That MAP signal sure looks like a 1-cylinder!
If your fueling calcs are using MAP (they are) then you're really going to need to find a way to get that smoothed out... or use Alpha-N.
zuelkhairiey
it is 1 cylinder
can I make tuning more easy by using the hybrid alpha n?
can u suggest how to tune it step by step :roll:
i'm still new....
zuelkhairiey
i have tried using alpha n
n it give a better idle,i think
here i have another datalog for reference and hope anyone can advice me on tuning it
newtyres
Post by newtyres »
This is just a suggestion, try running alpha-n again, you should be able to get a good stable idle, then tune from there as described in the Megamanual. Set your throttle bins very close together at small throttle openings and make the bins progressively further apart towards full throttle, to give better drivability. You will have to do something about your tach signal, because at the moment Megasquirt thinks you are idling at 3000 to 4000rpm.
Ian.
fscott
Problems that I'm seeing.
Post by fscott »
First off, your coolant and intake temperature sensors don't seem to be working. They're stuck at 33 and 47, which means that the MS always thinks that the engine is cold and so is the air. Maybe it is 33 degrees outside where you are, but the coolant temperature should rise above 47 degrees as the engine warms up.
Next, your tach signal needs to be fixed. In the datalogs it shows the RPM's are around 4000, but you said that you're idling. What is the idle speed of the engine? I'm going to go out on a limb and guess that it idles at 2000 and that this is a wasted spark system. Most bikes are.
Do you have your constants set to one cylinder, one injector? If so, change to two cylinders, two injectors. This won't affect the amount of fuel injected, but will correct the RPM reading.
Lastly, your MAP signal is too rough. Look into using a restrictor and fuel filter to smooth out the signal.
Your MS just isn't getting good input right now. Until that changes, you're not going to be able to tune it properly.
whittlebeast
Post by whittlebeast »
Go straight to Alpha-N and dont look back.
AW
zuelkhairiey
i have a new datalog
i have eliminate the rpm problem, thanks fscott
so can u give me some tuning tips, and i'm still using speed density
i have a problem,my ms keeps draining my battery although the engine is running,maybe a wiring problem
zuelkhairiey
it seems that my fuel pump is draining the battery
the fuel pump is not controlled by ms through relay
do i have to ride it around to tune the ve table or i can tune it just by revving it?
zuelkhairiey
hi,today i have just put my ms through the ultimate test
a 200+ km of riding to my college
it went ok with a slight problem here and there
the 1st problem is my ms keeps resetting making it hard to start
the problem seems to be my volt meter that i put yesterday to monitor my battery voltage
it went fine after i disconnect it
2nd problem is a loose connector to my ms
3rd problem is the battery cannot supply enough power for the ms and fuel pump(car)
my bike died when i stop in front of my college because the battery is flat
i tried starting it about 2 hours after that, and it started fine
maybe its time to change the fuel pump
other than that it went ok coz i havent tune the ve table yet
i just use ego correction above 3000rpm and maintain the rpm below 7000rpm
this shown that the ms is a reliable
Who is online
Users browsing this forum: Amazon [Bot] and 26 guests
