Page 1 of 4
What is AutoTune?
Posted: Mon Jan 23, 2006 11:46 am
by Rollagti16
Hello, one quastion. :
What is autotune in megatune??
Posted: Mon Jan 23, 2006 4:10 pm
by efahl
Rolla,
Auto-tune is an algorithm in MegaTune's 3D tuning dialog that adjusts the VE table based upon feedback computed (usually) from the lambda sensor readings. It can be used with a narrow band sensor to tune the main part of the VE table to stoich, or with a wideband to tune just about all of the VE table.
Eric
Posted: Tue Jan 24, 2006 7:47 am
by Fastest95PGT
When using a wideband and AutoTune, does it aim for the target AFR map as opposed to stoich for a narrowband?
Posted: Tue Jan 24, 2006 7:51 am
by boost junkie
Its my understanding that autotune just goes off of the EGO correction. If you set EGO correction to use the AFR table then thats what autotune will use...
Posted: Tue Jan 24, 2006 7:57 am
by Fastest95PGT
Thanks Shawn.
Posted: Tue Jan 24, 2006 9:01 am
by efahl
Fastest95PGT wrote:When using a wideband and AutoTune, does it aim for the target AFR map as opposed to stoich for a narrowband?
As Shawn says, it simply tries to minimize the error in the control variable, which is almost always set to be EGOcorrection. The tuning algorithm looks at the value of the specified output, sees if it's 100 and if it's not it adds/subtracts something from the current table entry to move the output closer to 100.
Code: Select all
   correction     = EGOcorrection_value
   value          = VEtable_value / 100.0
   steps          = gain * value * (correction-100)
   VEtable_value = VEtable_value + steps
There are a bunch of other parameters dictating when this can happen (both in terms of proximity to a node and frequency of updates), which should not be too loose or too fast or the algorithm can become unstable.
Eric
Posted: Tue Jan 24, 2006 9:07 am
by ochizon
Im sorry if im a little dense...
There are 2 functions for autotune?
1. Autotuning the VE table: Sets the VE output based on the wideband acheiving the desired output.
2 EGO correction: Once the VE table is set in stone, the wideband functions only for minute alterations to maintain the desired AFR output.
Is that right? Or is it ONLY #2?
Posted: Tue Jan 24, 2006 9:28 am
by Fastest95PGT
Thanks for the expanded clarification Eric.
I am wondering if you need to be in closed loop for AutoTune to work with a Wideband since no EGO correction is going on?
Posted: Tue Jan 24, 2006 9:47 am
by efahl
ochizon wrote:There are 2 functions for autotune?
Well... Actually both simultaneously. Your MS will compute EGO correction and apply that internally. MT's auto-tune algorithm is watching that EGO correction and minimizing it by messing with the VE table. Obviously the MS does its EGO correction all the time (assuming closed loop is enabled), but MT can only do its bit when you have MT connected to a running engine.
Eric
Posted: Tue Jan 24, 2006 9:55 am
by efahl
Fastest95PGT wrote:I am wondering if you need to be in closed loop for AutoTune to work with a Wideband since no EGO correction is going on?
Now that you mention it, no, you wouldn't necessarily need to be in closed loop mode at all.
You could set the auto-tune up to do something like this, which would work irrespective of whether you were running closed- or open-loop:
Code: Select all
[OutputChannels]
   lambda    = { 1.5 - 5.0 * egoADC/255.0               }
   afr       = { lambda * 14.7                          }
   targetAFR = { vexInterp(rpm, map, 0, "afrtable.vex") }
   AFRcorr   = { (afr / targetAFR) * 100.0              }
[AutoTune]
   table = veTableMap
      corrector = AFRcorr
Just make up a vex file "afrtable.vex" and you're off to the races.
Eric
