Tuning w/ v2.2
shelbydodgeimp
Tuning w/ v2.2
I was wonder how hard it is to tune an engine using the v2.2 board, is this the type of project that would require a dyno or can the MS "monitor/log" the existing fuel injectors to generate a basic fuel curve from which to start from?
Sorry for such a "noob post" but I am curious what I am getting myself into.
1990 Chrysler 5th Ave (every option but sunroof)
1992 Shelby Dodge Imperial R/T Concept
Tuning is not particularly hard - but like most things, it depends on how much you know, and how much experience you have.
To help the knowledge side, read the tuning guide at: http://www.megasquirt.info/v22manual/mtune.htm (then re-read it a few times!
For the experience side of things, if have tuned carbs, or you know someone who has that can help out, that's a big help. However, it's entirely possible to start from scratch on your own and end up with a good tune, it just takes longer.
The additional time is because most people generally make a few assumptions about how things work (that turn out not to be true), they don't follow a plan (changing one thing at a time for example), and they think some things are irrelevant (not very often), and they don't recognize the symptoms that occur (like a backfire into the intake manifold under acceleration almost always means lean, etc.).
Most of the tips you need to know are in the above link.
bimmersquirt
I use this method sometimes,MS "monitor/log" the existing fuel injectors to generate a basic fuel curve from which to start from?
ie: I fit the MS but not to action the inj/coil
put all my constants ect in, then using a WB02 go for a drive and log what/where AFR the stock setup uses
It does help, I log, then generate a target VE based on the results, then basemap, EGO trim , log and go driving.
at the very least the car should eventually drive "stock" to a fashion using the targets as a guide, then you can play and feel where gains are to be had
dont help with ignition though
