Coilpack with wasted spark with NO EDIS ?
That way, I could run a coilpack directly on my 4cylinder, without an EDIS module.
If it's possible to add one, how hard it is ? Also, is the software able to run it ?
On another side, is it possible to drive a coilpack with only one VB921 driver and run in triple wasted spark ? Like by tapping the two trigger line on the coil with the coil driver from the v3 ?
Thanks in advance!
-Phil
So here's a few possibilities that I could use:
1: Use an EDIS module with a coilpack in a wasted sparks configuration.
2: Use my stock distributer (I'd prefer switching to coilpacks for reliability issues and simplicity)
3:Use MSnSE, and add a second coil driver like this :
http://megasquirt.sourceforge.net/extra/setup-neon.html
He's using IGN and IAC2B (DB37 pin36 and 31) output pin to drive the two coils triggers (have to modify the v3 board a bit).
4: Add a secondary coil driver like above, use MS2, and hope for a code implementation of it! I wonder how hard implementing this would be on the MS2? This would be great since there won't be any need for an ignition module at all and no more distributor.
If there's no way to add a second coil driver on v3 board with ms2 and use it properly, I'll use the EDIS solution, it's not that bad anyway!
jsmcortina
- MegaSquirt Guru
James
Nice, hope to see that day come. Meanwhile I'll just get an EDIS module then.There isn't code yet for MS2 to drive two or more coils, but it is on the wishlist.
James
By talking about a wishlist for MS2, is there a place we could see that list?
I'd be curious what are the future plan for MS2 code!
I'm a programmer myself (I know assembly, C, C++, VB, and a few more) but I'm pretty much learning on how the electronics works on car. I have learned a lot but there's so more to learn still..
Anyway I may give a try on reading the code, and see if there's a way I could help. Is anyone welcomed to add a bit of code, and send it to Grippo to possibly add it for the next release?
Yay ! more readings
2.4tneon
