Coils with built in ignition drivers?
Gary
I'm looking to use microsquirt for a 6 cylinder wasted spark (GM 3.4L V6 and porsche flat 6). Understand that the intended application of microsquirt (motorcycles / watercraft) trumps the need for 3 onboard ignition drivers, but wonder if there are stock applications out there with coils/ignitors in one unit.
I've been surfing msefi, ebay, summit, etc. looking for which coils have built in ignitors/drivers. Not much luck (at least with how I'm surfing). I've seen the bosch coils used on VW/audi - they're big and pretty expensive.
If need be, I can put 3 VB921's on a board in a seperate box, but that seems like a kludge... Also could go with a DIS or EDIS box, but really hoping to leverage the -9S12 speed to decrease parts count.
jsmcortina
- MegaSquirt Guru
LS1 coils are "smart" logic-level coil-near-plug units.
If you extended the Microsquirt code to support a third channel, you could easily fit another ignition driver chip to the inside top of the case as there is plenty of room.
James
muythaibxr
The signal is weird in that one signal is the advance every 120 degrees of engine rotation, and the other two signals are "coil select" signals that tell the ignitor to which coil pack the dwell/spark are supposed to be applied.
Gary
reading James' comments, it looks like when Microsquirt is released, it will support two coils. Not sure why there are two tach inputs (must be for odd-fire support), but will check the code and release notes when it comes out. Seems like extending the code to a third ignition output won't be a huge chore.
jsmcortina
- MegaSquirt Guru
Many bikes use dual VR sensors from the factory and a single tooth on the crank. The Microsquirt should wire right up to it.Gary wrote:Ya-but,
James
sparkandfuel.com
like the toyota multiplex in msns-e? that was written for the 7mgte, and was reported to work ok if rigged right.muythaibxr wrote:The toyota 7mgte coil/ignitor pack is used for controlling 6 cyl engines in wasted spark configuration. IF someone wrote code to support the weird inputs it takes, you could drive it with a few simple pullups to +5v with a few transistors. I'm not sure that's any easier than using vb921's though.
Who is online
Users browsing this forum: No registered users and 38 guests
