Specifications, applications, part numbers, and prices for various OEM fuel injection components.
Picked up a set for my GS for cheap. All fine, the sensors hook up real nice and easy, BUT there's this whole suction-piston setup thing. There's a little cylinder on top of those throttle bodies, and shields before the throttles (like in carburetors). So far I could not find out how it hinders me, other than the shields being somewhat obstructive (although I think they retract under vacuum). But I just want to make sure that I don't need to make any special accomodations for this throttle body.
It came out of an R6, and I'm going to be using it with 3.0 MSII and an in-tank fuel pump.
Also, the thing has a vacuum line going to the fuel pressure regulator - is this normal?...
If this is the same sort of thing as my CBR bodies then the thing on the top is
Idle/warm up and works by bleeding air through bypass holes. if you look at the inlet side of the bodies there should be some small holes the go to the outlet side of the butterfly.
the other things are to keep air flow at maximum velocity, so when you slam the throttle open they open more slowly to keep air speed up. I think they are like the slides on an old CV carb
Ok, that sounds good... But how do you control the warm-up thingie? It has no cables going to it, just two hoses and that's it.
BTW, there's an idle adjustment screw also,
Petrovich wrote:Ok, that sounds good... But how do you control the warm-up thingie? It has no cables going to it, just two hoses and that's it.
i know nothign about this setup, but i'd hazard a guess engine coolant just goes through the hoses and the valve thing is some kind of thermostat. try hooking it up to the hot tap in your house(if you think itl be alright to put water through it) and see??
14.5@97 in a fully loaded daily driven classic mini
I think your correct about the coolant controled warmup. i am sure it could be replaced with a stepper motor if you wanted a lower idle, most bikes tend to tick over quite high (1.5-3k) and than drop as they warm up.
