high impedance injector settings
Posted: Wed Mar 08, 2006 6:52 am
by scottymk2
hi there,
sorry to post this, as its probably been asked before and maybe im being stupid..
but im setting up my msII v3 in megatune, but im highly confused - the megamanual seems to contradict itself - please help!!
under the "PWM Time Threshold (ms)" it sasy set this to the same as injector opening time ~ 1.0ms
under the "Injector PWM Period (usec)" it says set this to between 10 and 25KHz...
it then says if you are running high impedance injectors:
set the PWM time threshold to 25.4ms
so, should my PWM Time threshold be 1.0ms or 25.4ms???
and what should my "Injector PWM Period (usec)" be?
Many Thanks!!
Scott
Posted: Wed Mar 08, 2006 7:09 am
Scott,
Set the PWM time threshold to 25.4 milliseconds for high impedance injectors.
You only set it to something else if you are using PWM (I.e., with low impedance injectors). The insrtruction to set it to the same time as the injector opening only applies to those using PWM for current limitng with low impedance injectors.
