WRX 440cc blue injectors
deepnsteep
Post by deepnsteep »
Does anyone have some measurements for these injectors?
Thanks!
Levi
natesully
Post by natesully »
By measurements, you mean impedence-right? Chances are that they are low, as with most modern injectors. Also, it's funny that you mention blue 440cc injectors, since my blue 440cc DSM injectors are low impedence. Think they might be the exact same thing?
95 Miata M-Edition, GT28 Turbo
deepnsteep
No, I believe that the WRX injectors are high impedence. I was actually looking for some physical measurements. In particular, I need to know the body diameter.
Thanks!
Levi
whittlebeast
Post by whittlebeast »
The teal blue section is real close to 16mm. 63mm total height. My calipers at work have a dead battery. Thats as close as i can get.
AW
deepnsteep
Thanks Andy!
