Real time baro correction using the stock Ford BP sensor
Posted: Sat Mar 11, 2006 1:13 pm
Anyone done this yet? Or a better question, is is even possible?
I was going to try and re-use the existing BP sensor already installed.
Found this regarding the output of the sensor:
http://fordfuelinjection.com/index.php?p=32
Apparently it outputs a Hz frequency signal as opposed to voltage. Is there a way to define this in MT or am I better off to look for a GM unit?
