Constants and how MS works
Hope someone can help with my understanding of the constants page.
If we consider a 4 stroke engine.
Am I correct in thinking the number of cylinders in the constants page is saying how many pulses the MS gets per 720deg of crankshaft rotation ?
So for a 4 cylinder engine set to 1 squirt and simultaneos staging, does MS fire in injectors every 4 pulses of the ignition input ?
What difference does the throttle body or Port make ?
Many thanks
Barry
detcollector
You are correct with your engine cylinder/cycle understanding.
But don't think you can fudge the cylinder number to get the injections right as the number of cylinders also tells MS how many ignitions there are for a cycle and hence it claculates the RPM.
I haven't looked at the throttle/port parameters but pressume thats so it knows if you have throttle body injection or injectors for each port.
jsmcortina
- MegaSquirt Guru
Re: Constants and how MS works
None at all - the code doesn't use it!bazzer wrote: What difference does the throttle body or Port make ?
I'm assuming that a VERY early version of the code had planned on using it but that never got implemented and no-one noticed to remove it.
James
James,I'm assuming that a VERY early version of the code had planned on using it but that never got implemented and no-one noticed to remove it.
Yes, I think that is right.
If I recall correctly (which is 'iffy' at the best of times) Eric never removed it partly because I think there may have been eventual plans for it (perhaps for things like 'auto-generating' warm-up enrichments, sort of like the VE table estimator), and also to maintain continuity (in case someone else with a custom code was using it).
But for the official code it has always been a 'placeholder' rather than a variable actually used in either MegaTune or MegaSquirt. Interestingly, with X-Tau accel enrichment on the way, it might be useful once again....
From Manual
If you have a throttle body injection (TBI) system, verify that there is a small squirt of fuel (equal to the “prime pulseâ€) when MegaSquirt is powered up (by turning the ignition key to run), . . .
