Fuel pump screaching
Posted: Mon Mar 27, 2006 2:04 am
Need some input on this situation...
This is how I currently have the plumbing hooked up
Tank pickup to a brass tee, one side of tee to fuel filter, to pump (walbro gsl392), to fuel rail, to regulator, and other side of regulator loops back into the second end of the tee mentioned previously. Tank and filter are strapped to subframe near rear tire.
Has been running for several thousand miles like this w/o issues for my mpfi setup. Previous to that, similar plumbing with a gsl395 pump for tbi had no pump issues.
Recently this issue has cropped up. Upon initally starting the car that day after sitting overnight, everything is fine, pump sounds normal. After the drive, the pump sounds very screachy, not healthy at all, but engine runs ok all seems well otherwise. Pressure is maintained according to underhood gauge.
Every now and then, very hard to duplicate consistently - when the temps start to climb in stop and go traffic, the pumps screach gets even louder and louder, pressure drops until the engine stutters and dies. Try to restart, same issue, engine shaky, pump screachy... after few attempts to start and keep the car running, and traffic traffic lets up, get back to speed, all is normal and well.
I can sit idling in the driveway with the pump screaching, w/o issue. If, after sitting, and before driving the car for the day, I take 12v to the pump and run it w/o engine on for 15 min, there is no screaching.
I think I may be overheating the pump by taking the hot fuel return to the pump input instead of the tank (don't have provisions for fuel return to the tank, but thats in the works now....) What are your guys thoughts ont he situation? Is it possible for the pump to get noisy only when its hot, and aren't they designed to pump warm/hot gas? Should I replace the pump as well just incase it may of gotten permanently dammaged?
