Ignition breakup
Ignition breakup
MSII v3 board, with v2.3 code
I am using the ignition driver circuit to directly run my coil. My question is if this has enough current capacity for a hot spark. I have this installed on a 2.8L turbo and have had really good luck when I run low boost. The problem is, low boost is no fun. Around 15psi and 4000rpm, the engine starts to miss. At 13psi, no miss anywhere. AF is a steady 12.5:1, so I am thinking it has to be ignition. I tried messing with the dwell settings and had a fair amount of luck.
Max dwell, 5.6ms
Max spark duration, .8ms
Increasing the dwell doesn't do any good, since at high rpm, the dwell HAS to be less than what I already have the max set at. Decreasing the max spark duration allows for more dwell, but seems to be reaching a point where the engine misses because it is too small. I am driving the stock coil ('83 Nissan 280zx turbo) which didn't seem to have any problems with ignition on the stock setup.
Any insights? Thanks a ton!
-jeremy-
Have you tryed reducing the gap about .005?
I was gonna look into getting a DIS-2 from MSD. Installing one for my app and not using the timing retard, the unit acts a power adder for the ignition system.
So you are haveing better luck with a lower spark duration? I had mine set to like 3.5 ms and turned it UP to like 25ms to see what happened. I saw no change though
