80kPa on idle?
80kPa on idle?
IMHO 80 kPa is definitely not correct. Means that you have hardly any vacuum in your inlet manifold. If I were you, I'd check the intake for any air leak between the buterfly and the head: injector bungs, manifold to head gasket, vac line to the brakes, well every hole in the inlet or junction should be air tight. What you can use for that is get your engine idling (if this is possible at all) and then move a fuel soaked paintbrush around the whole inlet system. If there's a leak, it will suck fuel vapors and the RPM will go up when the brush is close to the leak.
Hope this helps, Séb
And old volvo's are forever...
