Very high VE values at low RPM
Posted: Fri Mar 31, 2006 1:52 am
Hi,
All the time I've been tuning so far, I tend to get extremely high VE values in the low RPM/medium to high kPa when using MSTweak. I've once seen a topic about it where people talked about air leaks in the buterfly axle that would allow for a sudden increase in pressure as soon as the throttle was depressed. The proposed solution was to use high VE bins in that zone to cure it. I did it without much success and I still stumbling when the engine idles and I give a kick on the throttle. AE does not much to change the situation.
Also, when the the engine is in the 1500 and 2200 Rpm bins under full throttle (about 90 kpa), it stumbles until it gets into the 3000 rpm/90kPa bin. Then it starts pushing like hell. I've tried enriching and enleaning the incriminated zone and nothing does the trick.
Are these issues known ones, are they separate or not??
Attached is my latest VE map and 2 HDMAP files (from two separate bunch of logs) zipped for you to see and hopefully comment.
Thanks in advance, Séb
