Injector port type
Volkkarijermu
Injector port type
Post by Volkkarijermu »
What's is the difference between "Port" and "Throttle body". What MS does when "Port" selected and what when "Throttle body" is selected?
the bubbler
Post by the bubbler »
I suggest you have a read through the megamanual, as this is all covered in that.
Basically port injection tends to feature an injector per cylinder, usually pointed directly at the inlet valve.
Throttle body injection tend to feature a single large injector, mounted further up stream, and acts more like a well tuned carb than port injection.
Mike_Robert
Post by Mike_Robert »
The code doesn't do anything different. The full explanation is here:
http://msefi.com/viewtopic.php?p=109348 ... ody#109348
-Mike
