The following are pure newbie question, but I just would like to start fine.
I intend to convert a Rover V8, running on Edelbrok 500cfm carb and Tartarini LPG gaz injection to MS V3/MSII using the latest code. At first the mod will be applied on the 3,5 Ltr (215 Ci) and once everytning will work including the EDIS 8 I will swap the engine to a brand new 4 Ltr (250 Ci)
Question :
1 / I would like to know if the dual pole switch, one pole for the fuel table switch and one for the ignition (using the NOS switch) could work at the same flick or do I have to operate separatly. I intend to wire the fuel table switch as describe in the MSnS-E ww site.
2 / I intend to use LPG Keihin injectors. Fuel injector on chanel 1 and LPG on 2. These injectors are 1,2 Hom, and I wonder if 8 low impednce on one channel could be handled by the V3. The fuel injector are the Lucas high impedence cleaned and matched.
3 / If Mitsuko is around, my LPG set up is based on the Tartarini LPG injection system, I want to get rid off the actual dual stepper flow control and ECU. I have two constant pressure regulator and I just want to be sure if I must connect the vent port of them to the MAP manifold shared by MS.
4 / Last one, regarding the sizing of the LPG injectors, how to evaluate the size of them. Mitsuko, I have the same kind of dealer you have, willing to help and order spares for me... but I would like the first one to be the good one (orange dot or yellow dot ??, I will use 8 in two Prins style frame bolted on my plenum just near by actual injection points in order to optimise the ruber hose length)
Thanks to all.
Sorry if I did the things wrong for the first post.
