LC1 wideband reading lean but meagatune reading rich
Posted: Thu Apr 13, 2006 11:05 am
by johnhickey
System: MSII, embeded 2.32, MT 2.25, V3 main board, Innovate LC-1 wide band.
I have the engine running on a dyno at a steady condition.
Using the logworks software supplied with the LC-1 wideband O2 sensor the A/F ratio is reading 18:1 and flickering a little as it should be. Megatune however is reading 12.1 constant. I have verified the analog output of the LC-1 is putting out the correct voltage all the way to ADC5 on the MSII daugtercard. The .ini file is configured for the LC-1 wide band sensor. Data log of ego parameters is below:
egoVoltage AFR1 AFR2
12.1 12.1 12.1
12.1 12.1 12.1
12.1 12.1 12.1
Can some suggest a process to debug this issue?
Posted: Thu Apr 13, 2006 11:16 am
by darkstarmedia
Be sure your sensor ground and the MS ground are in the same place. these must be tied together. if they are not you will see different readings.
Posted: Fri Apr 14, 2006 2:40 am
by johnhickey
Thank you very much for the reply Richard. The grounds were definatly a good idea, however I double checked them & they are tied together.
I do have a 3.6-3.7V signal at AD5-1. This should be around 18:1 A/F using the default LC-1 calibration of 7 to 22 A/F = 0-5V.
Attached is a PDF graph from a data log showing A/F ratio clipping at 12.1 on the low side but jumping to 14.6 during a portion of a run. This leads me to believe the signal is there but not scaled or configured properly.
How can I verifly in the Megasquirt-II.ini file that the proper configuration & scaling is there?
Posted: Fri Apr 14, 2006 3:56 pm
by johnhickey
I determined I had not calibrated the Ego sensor in megatunes calibrates sensoir menu. All is well
