MS V3 Mustang 5.0 flooding and hell rich.
Posted: Fri Apr 28, 2006 8:23 am
by nabil
hello guys;
I got a friend who had someone install MS V3 on his mustang, he told me that when he connect the TPS the car doesn't start, I have no idea how did they wire the car but its a fuel only setup.
I noticed that when they connect the CTS the car floods and doesn't start, when they connect the TPS the same happened, I have setups from other cars that I have tunned "but with V2.2, doubt that would make a difference" but that did not solve the problem. they have set it fueling alternating mode and # of squirts to 8.
when I change that to 2 or make it simulatneous and 1squirt it floods and doesn't start again.
if I disconnect cts turn it on then connect cts it runs so rich that it dies.
any ideas what can be wrong? should I check all the wiring?
best regards
Nabil
Posted: Fri Apr 28, 2006 8:57 am
Nabil,
Yeah, that certainly sounds like a wiring problem. If you post a datalog we might be able to spot other problems.
Posted: Fri Apr 28, 2006 9:49 am
by pfabricy
Sounds as if the TPS might be wired backwards. It would be easy to do but you should notice it in Megatune.
