I'm on MSII V3 board with 2.34code, MS is running a single fire coil and I've another tacho hooked off the negative terminal of the coil. My problem is that this external tacho reads about 400rpms lower than whats on the Megatune screen. Anyone got any ideas what to check for to solve this? Thanx.
If the second tacho is a tachometer then I am not surprised at all that it is 400 rpm off. I have seen a difference of at least 200 rpm on my car and I have an expensive (not a good) tach. To me this is a disgrace. Any ECU counts pulses and has a very accurate timer so you can count on the rpm you see coming out of the ECU as long as the times are taken from the internal computer clock and there are no missed pulses which would show up as erratic rpms. If at steady idle your ECU reads a steady rpm I would trust it over a meter any day.
That's normal for that kind of setup. You don't have a plenum to smooth out the pulsing. I have a plenum but a very large cam and it fluctuates like that.
