How to test a VB921
bleoh
How to test a VB921
Post by bleoh »
I've searched and seen it asked a couple of times, but could not find an answer.
Is there a way to test the VB921? Thanks. Brian
MS2 v3.0 MT2.25 controlling 6 high z injectors and ignition
bleoh
Post by bleoh »
btt.
woh
Post by woh »
You can test it easily if you have a stimulator. Modify the stimulator as shown in the assembly manual.
http://www.megamanual.com/ms2/V3assemble.htm#output
bleoh
Post by bleoh »
Thanks woh. I think I forgot all about that part of the assembly because I am using the fuel pump relay to make sure I don't burn up the coil.
Karl
there is another way too
Post by Karl »
I had a bad vb921 that looked good on the stim. Use an ohm meter to check the resistance between the leads when on and off. My still switched but it leaked alot when it should have been off.
