Page 1 of 2
4 pin and msd
Posted: Wed May 17, 2006 6:47 pm
by elturbonitroso
ok guys ms1/msns-e v2.2 and here is my ? because i been :RTFM: and im confuse about how to do this set up my distributor has a vr sensor so i have to conditioning the signal and im going to use a 4 pin module my ? is if i have to put the 1k resistor in pin C of the module or a 470 ohms from pin C and B and also if a have to put a 1k from fidle to the white wire of the msd.thanks
Posted: Wed May 17, 2006 10:07 pm
by turbo355
I use the 470ohm resistor between c b with a four pin hei butt i use the led 17 option be sure to use a good name brand module i had some problems with tach spikes then i changed modules and been fine since.
Posted: Thu May 18, 2006 2:58 am
by elturbonitroso
im going to use one from autozone im think is a wells brand which one you use in case the one that im buying is the same one that you have the spike problem .
Posted: Thu May 18, 2006 1:32 pm
by turbo355
I would try to stay away from the cheap hei modules maybe try a accel or msd module from jegs or summit autozone somtimes cary msd products they give a higher more stable voltage to the ms than the cheaper ones do my cheap one only put out like 1.3 volts to the ms and had real bad voltage spikes at anything under 2000 rpm and was real hard to start.
Posted: Thu May 18, 2006 5:15 pm
by elturbonitroso
do you know the p/n of the msd one.
Posted: Thu May 18, 2006 8:19 pm
by turbo355
Im not sure on the msd butt the accel part (there are two part # one is a hi-po thats good to 9k rpms)
standerd module # is 110-35361 $39.99
hi-po module # is 110-35367 $65.99
Either one of these should work great.
Posted: Fri May 19, 2006 2:50 am
by elturbonitroso
ok good but somebody with a good info in the resistor.andthanks turbo355
Posted: Sat May 20, 2006 1:06 pm
by elturbonitroso
nobody.
Posted: Sat May 20, 2006 2:29 pm
by MegaScott
elturbonitroso wrote:nobody.
470ohm 1/2 watt resistor
Posted: Sat May 20, 2006 5:09 pm
by elturbonitroso
so i dont need the 1k for nothing from the distributor vr sensor + to W - to G the 470 1/2 watt resistor in B and C. from C to pin 24 of the squirt and B to a 12 volts source. and from pin 30 to the white wire of the MSD and i dont need the 1k in pin 30 either.
